Hi Brave Community,
Could someone guide me on how to add my website syeddanishali.com to the Brave search engine, similar to how it’s done on other search engines? Or is there an alternative method I should consider?
Thank you!
Hi Brave Community,
Thank you!
To add your website to the Brave search engine, you can follow these steps:
Additionally, if you’re looking to enhance your website’s visibility, consider optimizing images with a picture editor to attract more visitors and improve engagement.
