NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
How to add another iOS device to an existing SYNC chain?
Goto Sync, see the sync devices, click add BUT the brave on my new iOS device doesn’t have camera to take photo
Always
1.35.104
iPhone 12 Pro Max
I’m using MACOS 12.2.1, My iphone is iOS15.3.1, I already add my ipad to the chain (using key in the code, also can’t use camera to take the QR CODE)
