How do i switch from uphold wallet to gemini?
You would just need to disconnect your Uphold account from brave and then sign in and connect brave to Gemini.
You will need to create a Gemini account, download the app and get it setup. It takes some time to get approved for everything in app.
I already have a gemini account, how do I connect?
@BeavisTheGreat essentially like @HighPriestess42 already told you. But I’ll break down the steps for you.
Go to your Brave Rewards icon in your Address Bar. When you click on it, you should see where it has the words
My Walletas long as you’ve got it connected. If it’s not connected, it will instead sayVerify Wallet. -
You’ll click on
My Walletand then choose toDisconnect from Uphold.
Then you’ll click on
Verifyand you’llLog Inwith your Gemini account. At this point, your browser should verify with it and start paying out with Gemini instead of Uphold in future payments. Well, assuming you’ve done all your KYC and all with Gemini.
Hi, it is not verified, so when I follow the steps, I can not see the disconnect link!
