Brave has been having issues ever since the most recent software update on my MacBook. Originally when I checked in settings it said “update failed (error 11) and I wasn’t sure what to do. I decided to try shut down my MacBook for a while and when I open it again I check and Brave attempts to update but I get instead “Update failed (error 12).
How do I fix both these issues, is there someone I can call, something I can do by myself, anything detailed at all will help.
Can you give me some more details please, like what macbook you have and the software it’s running
It is a MacBook Air, and it’s using macOS Sonoma version 14.4.1. Need any more information?
Thanks for the info! Maybe try reinstalling brave but don’t actually uninstall brave
