Description of the issue: No history is present in about:history / brave://history How can this issue be reproduced?
Don’t know. Could sometimes be an issue of low space, and brave … implicitly deleting, or truncating history files (even though I do not prefer that behavior)
Expected result: History is present, tracked.
Brave Version( check About Brave):1.90.128 Chromium: 148.0.7778.217 (Official Build) (arm64)
1 - I have this issue ongoing on desktop. I did check those settings, and have again. Nope.
2 - I don’t have it set, I have tried delete last 15m on pervious occasions, as an attempt to soft reset the system (blind to any informed reason that might help)
3- I do have low space, frequently run out, playing with the last 10G and 1G of free space notably often. This brave history absence issue persists, I think, even in sessions where there’s adequate disk head room from launch to close.
4- Interesting - corrupted profile. Low storage raises the chance of that.
4.1 - I do see desktop history on my phone, and not just typed links, as was a distinction some Discourse issues raised in 2023 and a bit before.
I was using BetterHistory extension for search. I’ve had that disabled for the afternoon, and still don’t see any history. I do see tabs synced from other devices on desktop.
