Will Shields still work after Manifest V3?
Yes, Brave will not be impacted by Manifest V3. You can read more about this on the official article at https://brave.com/blog/brave-shields-manifest-v3/
Youâll need to go to https://creators.brave.com/ and create an account. Then provide all the information requested. Things like links to your content and much more will be required. Also make sure you thoroughly read all the Terms at https://basicattentiontoken.org/publisher-terms-of-service/
If your Creators account has been suspended, the only way to get assistance is by emailing suspensions@brave.com. Creators suspensions are NOT handled on Brave Community or through support tickets. Emailing is your only option.
The Creators suspensions team typically reviews emails once a month, so the wait time depends on when they process the next batch.
When writing to suspensions@brave.com, be sure to answer these questions:
For issues like payments, not showing as Verified, adding channels, or anything else besides suspensions, itâs best to create a Creators Support Ticket at: https://support.brave.com/hc/en-us/requests/new?ticket_form_id=10061687185549
You can also post in Brave Rewards > Creators but most likely, youâll be referred to create a support ticket since theyâll need private information (like your accountâs email) to assist you properly.
For long-term backups, itâs essential to export your passwords, bookmarks, and wallet information manually. Sync should not be relied on as a backup solution since the Sync Code changes daily. Here are the best methods for backing up your data.
brave://password-manager/settings and click Export to download your passwords.brave://bookmarks/ and click Export Bookmarks from the menu in the top-right corner.brave://wallet/crypto/backup-wallet to get your phrase.brave://password-manager/settings and click Import to select your saved passwords file.brave://bookmarks/ and click Import Bookmarks from the top-right menu.For users who want to preserve more than just passwords and bookmarks (such as extensions or settings), you can back up your user profile folder. However, this method is not officially recommended as it can cause issues, especially with version mismatches.
brave://version and find the Profile Path. It will look something like C:\Users\yourname\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default.\brave-browser Folder\brave-browser folder with the one you backed up earlier.Note: This method is less reliable, especially if youâre restoring from an older Brave version. Issues may arise with extensions, settings, and version compatibility.
While Sync allows you to transfer data between devices, it should not be used as a backup solution. The Sync Code changes daily, and relying on it could result in data loss.
brave://settings/braveSync/setup and create a Sync chain. Write down the Sync phrase, but remember it will change every day.brave://settings/braveSync/setup, select I have a Sync Code, and enter the code (valid for 24 hours). This will restore your synced data.Always manually export and save your passwords, bookmarks, and wallet recovery phrase. Sync should only be used for syncing data between devices, not as a reliable backup.
Brave now allows users to export and import passwords and bookmarks on both Android and iOS. However, there is no direct backup solution for all data.
You can back up and restore your bookmarks by going to Menu â Bookmarks â Export Bookmarks or Import Bookmarks. For passwords, use Sync or another solution as no direct password export is available.
You can export passwords and are able to both import and export bookmarks:
When you export passwords or bookmarks, the files will be saved on your device. Since mobile devices are more vulnerable to being lost or damaged, itâs important to store these files somewhere secure, such as:
While Brave Sync can help transfer data between devices, it is not reliable for long-term backup because the Sync Code changes daily.
The Sync Code changes daily, and as Brave developers have stated:
Warning: Brave does not officially support using the Sync code as a backup and you should not rely on this continuing to work in the future.
Sync can work if youâre transferring data immediately or have other devices on the Sync chain, but itâs not a reliable long-term solution.
Itâs important to understand that Brave Sync is designed for syncing data between devices, not for backing up your data. As one of Braveâs developers has stated:
Warning: Brave does not officially support using the Sync code as a backup, and you should not rely on this continuing to work in the future. Use the export functionality in bookmarks and the password manager instead.
The Sync Code changes daily. This means writing down your phrase and trying to use it later to restore your data wonât work. Sync is intended for syncing data between active devices, not as a long-term backup solution. For reliable backup, use other options like exporting bookmarks or passwords.
At the time of writing, thereâs a temporary workaround if your Sync Code has expired. However, this is not guaranteed to last. Only the 25th word changes, and you can find the current 25th word here: https://alexeybarabash.github.io/25th-brave-sync-word/
Please donât rely on the workaround for the long term. The link could stop working at any time, and you may lose access to your data if you depend on it.
Sync Codes expire daily to protect user data. In the past, people accidentally shared their Sync QR codes or phrases, allowing unauthorized access to their data. To improve security, Brave made Sync Codes expire regularly to reduce these risks.
Step 1:
Settings â SyncHere youâll see something like the image below:
NOTE If you donât see these options, it likely means you have already started a chain. If thatâs the case, you donât need to progress further. Your page when you navigated to Sync should show your device and then also buttons that say View Sync Code and Add New Device. Both of those do the same thing but take you different ways to access the sync code or QR.
Step 2:
Start a new Sync ChainAt this point youâll get to a screen like below:
Step 3
Phone/Tablet it will show you a QR Code you can save to use. If you choose Computer it will give you a 25 word sync code.(screenshot below, though with some words blotted out. Temporary/blank profile anyway, just FYI.)
Step 4
Step 5
From here, youâre all set. Just need to add devices to your sync chain.
Keep in mind that, as I mentioned in Step 4, this Sync Code changes daily. If you hadnât seen it, make sure you read Sync is not a backup
Step 1
settings â sync and write down the code or be ready to scan the QR code.Step 2
Settings â Sync where you should see something like you do in one of the two screenshots below (if the first screenshot, then click on it to go to second screenshot):NOTE If you donât see these options, it likely means you have already started a chain. If youâre already in a chain, youâll need to remove it by clicking the trash or remove icon in the Sync menu where device name is shown OR you can go to brave://sync-internals (desktop or Android) or on iPhone click the gear icon on top right to get to Sync Internals, then click on Disable Sync (Clear Data) to remove the device from its existing sync. At which point should arrive to current step when going to Sync menu.
Step 3
I have a Sync CodeStep 4
ConfirmStep 5
You should now have your new device added to a sync chain.
Brave Wallet is a self-custody crypto wallet built directly into the Brave browser. Like other crypto wallets, it allows you to send, receive, and swap cryptocurrencies. Brave Wallet supports multiple crypto chains and provides live market data, portfolio management, and more.
Brave is actively expanding support for Web3, integrating new partners, and enabling users to swap assets and interact with Web3 DApps across various chains.
Brave Wallet is free to use, but as with all crypto transactions, gas and transaction fees may apply depending on the network or action.
Sometimes tokens are in your wallet but not visible. To see them, youâll need to either activate them from the Available Assets list or Add a custom asset to teach Brave Wallet what to look for.
Youâll see a screen like this:
Click the
button to access My Assets and Available Assets.
You should now see a screen like this:
Go to Available Assets and check if your token is listed. If it is, click the + to unhide it and make it visible in your portfolio.
If the token isnât listed, youâll need to add it manually. Click Add custom asset, then enter the required information like the token address and name.
Once completed, your asset should now be displayed in your wallet. If needed, go back to Available Assets to ensure the asset is checked and visible.
Unlike Android and Desktop, sharing logs for iOS is a bit more complicated. Follow these steps:
Settings on your device (not Braveâs settings).Privacy & Security.Analytics & Improvements.Analytics Data.Client.client.wakeups and click on them.Save to Files..ips with .txt (e.g., Client-2023-05-08-101535.txt). If prompted, confirm the extension change..txt file directly to your topic so developers can review it faster. While itâs generally safe, Braveâs Privacy/Security team recommends option 1 for maximum caution.Choose the method youâre most comfortable with.
Create a support ticket for issues that need it (e.g., missing Rewards payments). You can find more details on support tickets here.
If youâve created a Support Ticket, share the ticket number in your topic. This helps Support check in on your issue faster. Most communication will happen via email, not on the Community forum, so keep an eye on your inbox. Also, create your own topic rather than posting on othersâ. Tag Brave staff (e.g., @Evan123, @Steeven, @Mattches) if you havenât received a response after a few days.
Support doesnât work on weekends, so youâre more likely to get help if youâre active during weekdays. They generally respond within 2â3 business days, but if you havenât heard back after 3â5 days, tag them.
When responding to someone, tag them using @ followed by their username (e.g., @saoiray). This sends a notification and helps ensure they donât lose track of your issue.
Brave staff handles hundreds or thousands of issues daily. If you havenât received a response, it doesnât mean youâre being ignoredâit just takes time. Make sure to provide as much detail as possible to help speed up the process.
Make sure youâre posting in the correct category and providing as much detail as possible. For example, referencing the numbers on the screenshot:
Brave Rewards â Rewards Support instead of just Brave Rewards.Mobile or Desktop, based on your device.Always include specific information like the exact version of Brave (e.g., Brave 1.51.114) and your OS (e.g., Windows 11 or Android 12). Avoid vague answers like âthe latestâ or just âWindows.â
In addition, you should ideally be trying to troubleshoot and would provide as much detail on what you have tried and the results. You can check Troubleshooting Steps if you donât know what types of things you should be trying.
This issue happens because youâve accidentally created two different sync chains. Sync chains canât be combined, so youâll need to leave the sync chain on one of your devices.
Go to your sync menu. If youâre in a chain, it will look like this:
Scroll to the bottom. If more than one device is on the list, theyâll be displayed here:
If youâre not in a sync chain, youâll see this screen:
If your device is part of a sync chain and you donât see the image above, youâll need to remove a device from the chain to reset the sync process. After doing this, click on I have a Sync Code to either scan the QR code or enter the sync phrase.
You canât install Brave from the main site because it only provides the newest versions, which no longer support Windows 7 or 8. Instead, youâll need to download the last compatible version from GitHub: https://github.com/brave/brave-browser/releases/tag/v1.47.186
To choose the right installer:
Brave uses the Web Discovery Project to handle website indexing. You can read more about it at https://support.brave.com/hc/en-us/articles/4409406835469-What-is-the-Web-Discovery-Project
Essentially, there are no webmaster tools or ways to directly submit your website to Brave. Instead, websites are discovered and indexed based on Brave users who have opted into contributing to the Web Discovery Project. Once a site reaches an undisclosed number of views from different users, it gets submitted to the Search QA team for validation and to filter out potentially harmful links.
Unfortunately, Brave hasnât provided any webmaster tools yet, so thereâs no way for site owners to directly edit or update the information that appears about their sites in Brave Search. This is different from other search engines like Google, where webmasters can use tools to manage how their sites are indexed and displayed.
One method suggested by the Product Manager for Brave Search is to submit feedback directly from Brave Search itself.
On the search results page, look for the gear icon labeled âMore Settings.â Clicking that brings up a menu where you can change things like the pageâs appearance. Toward the bottom, thereâs a Share feedback button. Click it and provide as much information as you can. This feedback goes straight to the Search team, though thereâs no guarantee on how quickly theyâll see it or make changes.
Beyond that, you could try posting in Brave Search
in case any support staff or someone from Brave sees it and can relay the information. However, itâs been suggested that the best method is using the feedback form within Brave Search itself.
Cookie management has changed from what many people were used to due to upstream changes on Chromium. The key thing to realize is that using Delete Browsing Data will override any other settingsâyou canât whitelist sites there anymore; everything gets deleted. In other words, you will want to never enable this option unless you want everything deleted.
In order to counter this and give people control, Brave has added a setting called Forget me when I close this site in your Shields settings. If you enable it by default (Settings â Shields), it will erase cookies from sites when youâre done with them. Any websites you want to keep your info on can be whitelisted by adjusting the per-site settings using the Brave Shields lion icon in your address bar.
The opposite also applies: if the global setting is off, you can enable Forget me when I close this site on a per-site basis for sites you want to clear data from when finished.
