HELP! Not able to delete widgets and more
I don’t know if I’m in the right place or even how to do this (I’m VERY old )
After the last upgrade, the screen I go to when I want to go to a new page has changed. It moved the saved widgets and added ones I DONT need
But I can’t get it to delete the ones I want (and one I accidentally duplicated) and when I did a reset that was recommended, it wiped out my yahoo email!
HELP!!!
I don’t think that’s QUITE what they’re looking for @HeathM , though I certainly could be wrong, check out my and Saoiray’s post to a couple different users (Saoiray’s within mine) in the below link:
(Also I’m pretty sure your Yahoo! Mail is fine, you MIGHT need to just log back in, otherwise, if you could be more specific that would be appreciated :wink:).
(Either click the down arrow to the right and/or the header link)
Maybe a little of A, a little of B, no worries…
I know you’re frustrated about this though, so I hope you can work that out!
