Gmail won't load. I receive Gmail Temporary Error Numeric Code: 2
I have 3 separate Gmail accounts. 1 of them is working. I receive Temporary Error messages on the other two.
Everything is working fine in Chrome. I can’t tell whether this is a problem with Brave or a problem on Google’s end.
These accounts are included in my startup configuration. They launch automatically, and have for as long as I have used Brave. I have signed out of all my Google accounts and relaunched these, with no success.
Historically, each account opens in its own tab, as usual.
Ongoing.
Mac OS Sequoia 15.5
Brave is up to date
Brave 1.80.120 (Official Build) (arm64)
Chromium: 138.0.7204.101
Have you tried logging out, clearing cache/site data for mail.google.com and then testing again? Additionally, I’d be interested to know if you are able to login and view gmail normally if you were to login using a Guest window (Menu --> More tools --> Guest window)?
I tried More Tools → Open Guest Window. That worked. Next steps, to get it to work in a regular window?
I just cleared data. Problem solved.
