Gmail as of Aug 13 will not open in Standard mode, it forces HTML mode only on Brave Browser, please help!
Hi,
I’ve just joined here and signed in to state that I’m having the same issues. Been on Brave for many years now. Have tried all the posted suggestions, uninstall and reinstall didn’t have any effect. This is happening both on Win 7 and Win 10 for me (two different computers) and have only been trouble shooting the Win 7 version. On the Win 10 box I used Edge for the first time and was able to get Gmail to display correctly. Like the OP states the browser does NOT fall in the list of officially supported browsers.
I am so glad I am not alone, sorry to hear it’s happening to you also. :frowning:
@Alyssarya
All right, disable Scripts blocked now.
Okay and now I have taken the Shields Down again fully, and reloaded Gmail and sadly it is still in HTML format :frowning:
Jeez, what the hell is going on…
Try the following: enable Scripts blocked → agree to be redirected to the HTML version of Gmail → disable Scripts blocked → hopefully you’ll be redirected to the standard version.
Hahaha yeah I feel your Frustration Rethanis, believe me.
Before I even posted I researched online and tried a number of things, to no avail, as I didn’t want to just randomly post on here if I could fix it myself… but alas i was unsuccessful.
I really appreciate your help! :slight_smile:
I will try that.
Okay sadly no :frowning: still HTML after trying the enabling and disabling
I am also baffled by why this is happening now, when I’ve used this browser for so long and no issues at all. It is my main browser and loved that about it. I don’t want to have to go back to Chrome just for my Gmail…
Can you check whether disabling Hardware Acceleration via brave://settings/system has an impact? It doesn’t make sense but Hardware Acceleration causes unexpected issues in Brave now and then.
Tried it by turning hardware acceleration off, Relaunched the browser, relogged back into gmail and Sadly still HTML.
I also tried again to click at the bottom of the Gmail window for the Standard mode view option, and nope it reloads still in HTML despite that.
All right, let’s check whether the issue persists in a fresh user profile.
Follow the instructions below. Just make sure you close all windows of the current user profile after you create the new user profile, I want you to test while only the new user profile is active.
Okay I tried a new Profile and Gmail works as intended on it.
Funny enough, Old extensions I had on the original browser profile popped up on in the list, but I removed them and it still all seems to work. I didn’t even have to shut down the Shields for the website or anything, I made no alterations.
Just started a new profile and opened Gmail and entered credentials and all works normally.
So is there now anything I can do with my existing profile to have that happen to it also?
It sucks to have to use another profile just for Gmail haha… very odd
Not sure this is entirely a Brave issue. Goog is changing/moving to something called Workspaces and they have this list of what they support:
Changes at google
It looks like new things are recently being implemented and somethings are being taken away.
I read something titled “Google Meet support for IE11 ending August 17, 2021”, so this tells me something foul is afoot @goog
I hope the fine folks @Brave can find us a solution.
Why do things have to change? :_(
Ehm, what extensions? I thought you didn’t have any extensions in the original user profile?
@rgrainer
I believe Brave will be supported as well because it’s based on Chromium. I’m not sure why you two are having Gmail issues, everything works as expected on my end.
This is also happening to me, a new profile fixed it, but I’d love to know how to fix my old one.
Or a quick way to transfer all my bookmarks etc across to the new profile?
Version 1.28.105 Chromium: 92.0.4515.131 (Official Build) (64-bit)
You can export your bookmarks and passwords, and then import them into your new user profile.
brave://bookmarks/ → click on the 3 dots and choose import or export.
brave://settings/passwords → click on the 3 dots next to Saved Passwords → import or export.
@Mattches @sampson @rebron2000
Please, take a look at this thread whenever you have the opportunity. Multiple users are reporting the same issue, the issue is not present in a private window and/or a new user profile. I’m not sure what might be causing the issue as I can’t reproduce it on my end.
Here is what we know about the issue so far:
  • Clearing browsing data doesn’t resolve the issue.
  • Disabling extensions doesn’t resolve the issue.
  • Disabling Brave Shields doesn’t resolve the issue.
  • Disabling Hardware Acceleration doesn’t resolve the issue.
  • Resetting via brave://settings/reset doesn’t resolve the issue.
  • The issue is not present in Google Chrome.
@AgentStarling provided the following log through a DM:
Console log
mail.google.com/:1 [DOM] Found 2 elements with non-unique id #null: (More info: https://goo.gl/9p2vKq) <form id=​"null" action=​"?ui=html&zy=s" method=​"post">​…​</form>​ <form id=​"null" action=​"?ui=html&zy=d" method=​"post">​…​</form>​
m=a:1754 Deprecated API for given entry type.
fyd.activate @ m=a:1754
Bzd @ m=a:1832
Azd.initialize @ m=a:1829
_.V1a.onLoad @ m=b:722
_.u.gsa @ m=b:3883
_.u.gsa @ m=b:1068
_.B @ m=b:112
(anonymous) @ m=a:2206
(anonymous) @ (index):22
Promise.then (async)
B.<computed> @ (index):22
(anonymous) @ m=a:3
m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:210 POST https://mail-ads.google.com/mail/u/0/ads/main_jspb?rt=r&client=25 net::ERR_BLOCKED_BY_CLIENT
dao @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:210
$n.ha @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:206
hao.ha @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:214
M$n.ha @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:192
G$n.ha @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:185
(anonymous) @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:187
m6a.ha @ m=b:915
_.LG @ m=b:2289
uMe @ m=ebdd,sps,l,spit,t,lLYctc,anc:464
xMe @ m=ebdd,sps,l,spit,t,lLYctc,anc:465
zMe @ m=ebdd,sps,l,spit,t,lLYctc,anc:465
(anonymous) @ m=ebdd,sps,l,spit,t,lLYctc,anc:466
hUa.wa @ m=b:452
(anonymous) @ m=b:3483
hUa.wa @ m=b:452
_.BCc @ m=b:3500
(anonymous) @ m=b:3498
CCc.handleEvent @ m=b:3497
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
S5a.Ao @ m=b:898
D0a @ m=b:893
B0a @ m=b:671
Sw.ha @ m=b:670
D2b.ha @ m=b:2280
(anonymous) @ m=ebdd,sps,l,spit,t,lLYctc,anc:395
L2b.oa @ m=b:2284
y6a.wa @ m=b:929
O5a.Ao @ m=b:896
b3b.Ao @ m=b:2297
D0a @ m=b:893
B0a @ m=b:671
Sw.ha @ m=b:670
j6a.Ia @ m=b:913
g6a.wa @ m=b:908
O5a.Ao @ m=b:896
D0a @ m=b:893
B0a @ m=b:671
Sw.ha @ m=b:670
D2b.ha @ m=b:2280
(anonymous) @ m=b:3719
_.kM @ m=b:3719
Hhf.load @ m=ebdd,sps,l,spit,t,lLYctc,anc:986
uhf @ m=ebdd,sps,l,spit,t,lLYctc,anc:982
vhf.ha @ m=ebdd,sps,l,spit,t,lLYctc,anc:982
(anonymous) @ m=ebdd,sps,l,spit,t,lLYctc,anc:402
m6a.ha @ m=b:915
_.LG @ m=b:2289
S2b.wa @ m=b:2288
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
_.QG @ m=b:2294
QAc.hw @ m=b:3461
_.wDc.Ci @ m=b:3518
(anonymous) @ m=Zxsddf:38
l6a.oa @ m=b:912
h6a.Ya @ m=b:910
g6a.wa @ m=b:908
O5a.Ao @ m=b:896
D0a @ m=b:893
_.u.Qx @ m=b:669
_.i6a @ m=b:907
_.Cy @ m=b:922
m6a.ha @ m=b:915
_.LG @ m=b:2289
S2b.wa @ m=b:2288
O5a.Ao @ m=b:896
_.QG @ m=b:2294
_.BCe @ m=ebdd,sps,l,spit,t,lLYctc,anc:364
tLe.ha @ m=ebdd,sps,l,spit,t,lLYctc,anc:454
EUo @ m=Zxsddf:38
UUo.start @ m=Zxsddf:45
(anonymous) @ m=m,m_i,i20jfd,lKrWxc,hkjXJ,gYOl6d,HXLjIb,DL8jZe,xaQcye,oRmHt,E1P0kd,pE92lb,v2eEBc:1709
(anonymous) @ m=b:143
_.Fq.x6b @ m=b:352
_.Fq.I1 @ m=b:352
_.Fq @ m=b:352
nQa @ m=b:360
_.Lp.OJ @ m=b:359
_.Lp.kEd @ m=b:359
l @ m=b:360
w0a @ m=b:667
Sw.then @ m=b:673
pQa @ m=b:360
eQa @ m=b:360
_.Lp.OJ @ m=b:359
(anonymous) @ m=b:353
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
_.Fq.x6b @ m=b:352
_.Fq.I1 @ m=b:352
_.Fq @ m=b:352
nQa @ m=b:360
_.Lp.OJ @ m=b:359
_.Kp.kW @ m=b:747
_.Ax @ m=b:744
_.Kp.then @ m=b:745
(anonymous) @ m=a:1826
(anonymous) @ m=ebdd,sps,l,spit,t,lLYctc,anc:733
m6a.ha @ m=b:915
_.LG @ m=b:2289
(anonymous) @ m=ebdd,sps,l,spit,t,lLYctc,anc:459
m6a.ha @ m=b:915
_.LG @ m=b:2289
S2b.wa @ m=b:2288
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
_.QG @ m=b:2294
PFe @ m=ebdd,sps,l,spit,t,lLYctc,anc:402
_.u.$0 @ m=ebdd,sps,l,spit,t,lLYctc,anc:403
(anonymous) @ m=ebdd,sps,l,spit,t,lLYctc,anc:403
m6a.ha @ m=b:915
_.LG @ m=b:2289
fnc.Ha @ m=b:3182
(anonymous) @ m=b:3218
m6a.ha @ m=b:915
_.LG @ m=b:2289
hnc.Ha @ m=b:3184
_.u.Mpa @ m=ebdd,sps,l,spit,t,lLYctc,anc:805
(anonymous) @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:4853
(anonymous) @ m=m,m_i,i20jfd,lKrWxc,hkjXJ,gYOl6d,HXLjIb,DL8jZe,xaQcye,oRmHt,E1P0kd,pE92lb,v2eEBc:2067
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
_.Fq.x6b @ m=b:352
_.Fq.I1 @ m=b:352
_.Fq @ m=b:352
nQa @ m=b:360
_.Lp.OJ @ m=b:359
(anonymous) @ m=b:3885
_.T1a.execute @ m=b:719
e @ m=b:1201
Z1a @ m=b:722
_.u.gsa @ m=b:3883
_.u.gsa @ m=b:1068
_.B @ m=b:112
(anonymous) @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:28
(anonymous) @ m=rn4kU,yWJZbc,PaBahd,MMhUM,cs,zm225,o2ajQe,kRtote,Av2a7c,kbPIy,igbF5,Trl7bc,cv,dFpypf,MigGy,jVZ0pe,rMQdJc,Sz7W7c,CTcde,NVcOs,PZhDZb,Aihl6c,J03Die:5668
Unchecked runtime.lastError: Could not establish connection. Receiving end does not exist.
m=b:1000 POST https://mail.google.com/mail/u/0/flushimpressions?ui=2&ik=68e152ba31&jsver=g89G45E-siA.en_GB.&cbl=gmail_fe_210806.06_p2&_reqid=639114&pcd=1&cfact=7416%2C7782%2C7518%2C7514%2C7113%2C7433%2C7546%2C7057%2C7753%2C7682%2C7594%2C7677%2C7030%2C7758%2C7496%2C7424%2C7766&cfinact=7689%2C7683%2C7117%2C7544%2C7056%2C7521%2C7754%2C7543%2C7085%2C7082%2C7580%2C7595%2C7799%2C7058%2C7684%2C7767%2C7690%2C7640%2C7086%2C7802%2C7512%2C7577%2C7083%2C7084%2C7421%2C7563&mb=0&rt=j net::ERR_BLOCKED_BY_CLIENT
_.Wy.send @ m=b:1000
_.u.h8 @ m=b:1685
_.vD.Kub @ m=b:1665
_.u.Kub @ m=a:1762
_.NHb @ m=b:1666
_.vD.Ka @ m=b:1666
_.vD.send @ m=b:1661
_.u.send @ m=a:1760
_.u.send @ m=b:1645
Xsl @ m=lC97vf:9
Wsl.Ca @ m=lC97vf:8
(anonymous) @ m=m,m_i,i20jfd,lKrWxc,hkjXJ,gYOl6d,HXLjIb,DL8jZe,xaQcye,oRmHt,E1P0kd,pE92lb,v2eEBc:1023
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
(anonymous) @ m=ZThjHe,cXmWHe,mib1Lb,PDSZTe,Wwwwbc,pmnVQ,M184fc,ZUhrff,x8nlqe,xivAT,jPErQb,Z16oCd,wS0DLb,wHcxDd,Q8AZuf,MAQNkf,djoBOd,AQzzK:657
hUa.wa @ m=b:452
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
nQa @ m=b:360
_.Lp.OJ @ m=b:359
e @ m=b:1201
Z1a @ m=b:722
_.u.gsa @ m=b:3883
_.u.gsa @ m=b:1068
_.B @ m=b:112
(anonymous) @ m=lC97vf:11
(anonymous) @ m=lC97vf:15
m=f6apvd:10 GET https://mail.google.com/mail/u/0/?sw=2 net::ERR_FAILED
P7k @ m=f6apvd:10
u8k @ m=f6apvd:24
W8k @ m=f6apvd:54
_.R8k.Dvb @ m=f6apvd:53
(anonymous) @ m=m,m_i,i20jfd,lKrWxc,hkjXJ,gYOl6d,HXLjIb,DL8jZe,xaQcye,oRmHt,E1P0kd,pE92lb,v2eEBc:1026
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
hUa.wa @ m=b:452
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
nQa @ m=b:360
_.Lp.OJ @ m=b:359
_.Lp.kEd @ m=b:359
l @ m=b:360
pQa @ m=b:360
eQa @ m=b:360
_.Lp.OJ @ m=b:359
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
hUa.wa @ m=b:452
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
nQa @ m=b:360
_.Lp.OJ @ m=b:359
e @ m=b:1201
Z1a @ m=b:722
_.u.gsa @ m=b:3883
_.u.gsa @ m=b:1068
_.B @ m=b:112
(anonymous) @ m=f6apvd:56
(anonymous) @ m=f6apvd:60
/mail/u/0/#inbox:1 Uncaught (in promise) TypeError: Failed to fetch
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
hUa.wa @ m=b:452
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
nQa @ m=b:360
_.Lp.OJ @ m=b:359
_.Lp.kEd @ m=b:359
l @ m=b:360
pQa @ m=b:360
eQa @ m=b:360
_.Lp.OJ @ m=b:359
g.wa @ m=b:358
_.Lp.dma @ m=b:362
mQa @ m=b:361
_.Lp.kMa @ m=b:361
hUa.wa @ m=b:452
hUa.wa @ m=b:452
_.BCc @ m=b:3500
postMessage (async)
jCc @ m=b:3489
_.DCc.wa @ m=b:3498
_.JCc @ m=b:3499
PBc @ m=b:3499
HBc @ m=b:3483
_.FBc.Ao @ m=b:3480
nQa @ m=b:360
_.Lp.OJ @ m=b:359
e @ m=b:1201
Z1a @ m=b:722
_.u.gsa @ m=b:3883
_.u.gsa @ m=b:1068
_.B @ m=b:112
Known workarounds so far:
  1. Using a private window.
  2. Creating another user profile.
The solution so far:
Possible relations:
Nothing confirmed so far.
→ https://support.google.com/a/answer/33864
Click here
Using an unsupported browser
If you use Google Workspace on an older or unsupported browser, some features might not work, or an application might not open. For example, on an unsupported browser:
  • You may be able to view, but not update, your calendars.
  • You may be redirected to the basic Gmail interface.
  • Drawings and presentations in Docs editors may not display properly.
→ The latest Brave update, because users haven’t experienced the issue before that.
@hellodave
After you exported bookmarks and passwords, do you mind checking if resetting the old user profile resolves the issue? You can do that via brave://settings/reset.
Thanks for the replies.
I’ve just tried this, sadly no luck, still only loads standard mode.
Highly appreciate your quick reply and assistance, @hellodave!
Do you recall when the issue showed up? Was it after you updated to the latest Brave version?
