I have no extensions in Brave and yet Bing seach is being used still. Help! I do not want to use Microsoft products…
Try this jacquelyn https://search.brave.com/default
@jacquelynsauriol go to your Settings and change it then. Settings → Search Engine and choose the one you want as default.
Brave usually defaulted more to Google in the past, I think. Then since their own, it’s been defaulting to Brave Search. So for it to be Bing, means you, an extension you use, or a virus/malware is the one that switched it.
