Bing being used as search engine
My default and ONLY search engine in Brave browser is Google.
Recently (past 2 days) everything I search ends up redirecting me to Bing. I detest anything Windows.
I followed a previous post that had the same issue, it was fixed by reset of Brave settings? This worked for me, for around 5 minutes, then defaulted to ‘Bing’ and not ‘Google’?
When I type in a word in the address bar from the Brave home screen, I see the Google G logo. As soon as I press enter to search it will show me it used Bing instead?
[Version 1.13.82 Chromium: 85.0.4183.83 (Official Build) (64-bit)
MAC Catalina 10.15.6 (19G2021)
This is most likely a browser addon or other ad-ware interfering with your traffic. Try temporarily disabling all your browser extensions and re-enable them one by one, checking between each step if the problem persists.
Hi,
Thanks for the reply, I disabled all extensions and re-enabled them in turn, I found one that caused it to switch to Bing. It was a ‘Colour Picker’
No problem, glad that it fixed it, had that happen to me too before.
