Gemini reward not received for Dec 2021
Briefly describe your issue: Rewards for 12/21 were never deposited into Gemini. First month with this issue.
**What Operating System and Brave version are you using ( Menu --> About Brave )?Windows 11 Pro Version 21H2; Brave 1.34.80
Is your browser wallet currently verified? (yes/no) Yes
What date did you verify your wallet? Not sure, well over one month ago. Have received payment to Gemini before.
Have you been able to successfully receive payments in the past? Yes
Are you using a VPN? (yes/no) Used a VPN once or twice in last 6 months. Not a regular user
Are you in a supported region (see here for list of supported regions)? Yes
Does your device pass the SafteyNet check (Android only)? N/A
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? Yes, it has been turned off.
I’m going to bump this as I have not received an answer about why my payment went missing.
