Description of the issue: Some pages dont load properly while Youtube for example, works fine
Did the issue present with [default Shields settings]? No
Does the site function as expected when Shields are turned off? No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. No
Does the site work as expected when using Chrome? Yes
Brave version: V. 1.38.119
Also, while having the cursor on the Brave logo this appears (Access to Internet) so probably its not a problem of the browser itself but a Windows configuration.
