Device Sync between iPhone and Laptop
Description of the issue: Whentrying to sync my iPhone and Laptop the instructions say:
Sync Chain QR CodeOn your mobile device, navigate to Brave Sync in the Settings panel and click the button “Scan Sync Code”. Use your camera to scan the QR Code below. Treat this code like a password. If someone gets ahold of it, they can read and modify your synced data.
but there is no button on the iphone options.
As instructed
On laptop
  1. setting
  2. sync
  3. Start using sync
  4. Start a new sync chain
  5. Phone/Tablet
  6. Instructions as above to scan QR code
On iphone
  1. setting
  2. sync
    At this point is supposed to be the scan button but it doesn’t appear anywhere. If I choose ‘Add a new device under computer it lists the 25 text words for me to enter (I don’t want to enter text)
    If I select phone/tablet it shows a QR code but there is also no scan button on my laptop.
Reproduces how often: Always
v1.88.138 (Apr 1, 2026) on laptop
V1.88.(137) on iPhone
Microsoft Surface Pro 3
iPhone 12 pro
Hi nnn0a,
Thanks. It must have been still there from an earlier attempt.
