Default Bookmark location unintuitive
Adding a bookmark can really be such a chore. When I click the bookmark button I just want it to add itself to the bookmark bar. I can then either keep it there for quick access, or drag it to my watching / reading / learning folder later. But I then don’t want the next page I highlight to default to the folder I dragged my last bookmark to, I want it to show up on the bookmark bar! I’ve lost so many “watching” pages in my “learning” folder, “reading” pages in my “watching” folder, “business” pages in my “reading” folder. Stop trying to put my bookmarks all in the last folder I dragged them to, and just put 'em on the bookmarks bar by default.
I select “Bookmarks Bar” from the dropdown menu, I expect it to remember “Bookmarks Bar,” and not change that location as I later sort my bookmarks outside of that menu.
I personally prefer bookmarks being saved to the most recent folder as when I’m bookmarking stuff it’s usually in bunches and about similar things, but I might revise your request slightly to:
Have a default “New Bookmarks” save location…
Which we can turn OFF or ON
(because again I personally prefer bunching in the most recent folder)
and then for instance with it ON…
we can create an “Unsorted” Folder (or the Bookmarks bar as OP prefers)
and then we can go back to them when we’re ready and sort them
But good suggestion, I hadn’t really thought of it… the “Unsorted (by default)” thing is what I do in my Reminders App :wink:
That would be amazing to in that drop down menu have a option for when making new bookmarks and folders that there would be options for top of the list or bottom of the list kind of like the extension bookmark reorderer made by Daniel Herr.
You can add a bookmark to the bookmarks bar by dragging the icon on the left of the address bar to the bookmarks bar. You can even drag it into a folder there if you want.
