Description of the issue: Brave won’t launch at all.
It happened after I decided to delete a huge Brave folder (my bad) that after a quick google search I thought would be full of only partially downloaded files.
Brave then wouldn’t load a new page, so I tried a reinstall. Brave then wouldn’t launch at all. Tried a restart, wouldn’t launch. Tried a reinstall again, wouldn’t launch.
Additional Information: Brave worked fine up until this point.
My last Time Machine is a bit too old…
I tried searching for the Brave system file, but Finder wouldn’t let me check “System files” as in your screenshot. Is there a directory I could check manually?
I don’t know I did open some file using Text edit to check for the code in the browser and the app stop working. so I uninstalled Brave using CLEANMYMAC It’s deleted everything. After reinstall the app it’s work normally. I got this one on 1337x.to
