Can you please provide additional details about the issue? What exactly is the behavior when it “doesn’t work”? Are you saying that the settings aren’t applied? Or are the colors off? Or some other issue?
The tabs are not dark, as desired and set.
Obviously the ‘dark’ setting does not work at all.
Otherwise the tabs content looks good (but without dark mode).
@Mattches from the screenshot they shared, aren’t they using custom theme?
I’m guessing it’s the custom theme they have added which is the problem. Despite having Dark chosen, it’s not working on content because of it. I had a similar issue but it went away when I removed whatever theme I had at the time.
-NOTE-
Changing any of the theme color differences in the profile thing only seemed to barely change the exterior part of the browser. It didn’t change anything on the settings area. I think they are trying to say settings should be dark, such as:
@Saoiray yeah not sure how I missed that. @pileva2 definitely update to the latest build (1.75.178) and see if this resolves the issue. However, it’s likely the “Design slate” theme that is being applied causing the color discrepancy. If updating doesn’t work, try disabling it and see if that resolves the issue.
1.75.178 works better, but there are still conflicts with apps that have their own dark mode control.
But for now i am satisfied. Thanks for the support.
