Description of the issue: How can this issue be reproduced?
Everything was going well as always, yesterday when I closed a tab everything bugged and it was stuck without responding, when I tried to close it told me that it was responding, it gave me options to wait or close, I tried waiting countless times but nothing. I turned off the PC, turned it on. I opened it again, when I put “restore tabs”, the same thing happened. I restarted again, when I opened it, I can navigate, but if, for example, I close a tab, the bug appears again. The same thing happens with all the profiles I have created
Brave Version( check About Brave): Brave is up to date
Hi guys, it’s definitely the vertical tabs, because it works fine when I disable them.
But I don’t understand if this can be fixed, and I don’t know how, or if what you’re suggesting is just to check if it’s happening. It definitely happens to me when I have a lot of vertical tabs open and try to close them.
@fdst what was communicated to you is that this is a known issue that they are working on. They are trying to push a fix through. We will receive the patch/fix in one of the browser updates. I’m assuming it will be in whichever next update we get.
