"Confirm you're not a robot" screen
Description of the issue: The “Confirm you’re not a robot” screen appears repeatedly even though I’ve completed the security task.
Expected result: Being able to access Brave
Brave Version( check About Brave): 1.83.120
Mobile Device details: Motorola Moto G Stylus 5G 2024 (128GB)
Literally just happened to me, did a bunch of them for like 3 minutes straight and I still couldn’t search anything.
yes the same issue..
how it will be solved???
Same here while using a VPN. It makes brave search unusable, but other search engines still work.
Version: Brave 1.83.120, Chromium 141.0.7390.122.
OS: Android 13; Build/TKQ1.221114.001
Model: Poco X4 Pro 5G
Only occurs while using a VPN, but happens consistently.
There is currently an outage on the backend that is likely causing this issue. We’re working on getting this back to normal asap.
