Cleaning home page and remove most visited icons
Is it possible to remove all those most visited website icons, trackers, data saved, Est. Time saved from home page?
I just want blank page as I open Brave.
If you want a blank page = you can’t. But you can remove that widgets.
Then go to Settings > New Tab Page > and disable Sponsored Images.
And you’ll get an empty new tab page with background image. Not a blank page.
If you disable Background images too, then New Tab Page will show you an old design with all of those stats, etc, which can’t be removed.
It did the trick. Thanks.
But are those images come within apk or those Background images are fetched from some external server? If i can block that server in adaway, will i be getting clean page? Because browser will not be able to fetch any image.
I don’t know about that. I’m sure it’s fetched from Brave’s server and served locally. 🤷
