Changing the background color, how can I do it? It will not work when I switch to light
@jt21
Please edit your Original Post (“OP”) above, in order to include:
  • Brave Browser version numbers - required by Brave Support
  • Computing device Operating System version numbers - helps
  • The background color setting/theme that you might have established for your Brave Browser installation - unbeknownst to you by some incident of the installation (a bug?)
  • The background color setting/theme that you might have established for your OS
I am using Brave Browser (MacOS v14.8.4 Sonoma) vBrave 1.88.134, and the following are screenshots for the Brave Community URL address that you used:
https://community.brave.app/u/activate-account/8271cc5d9fa30f4d159b7da5bf414605
Brave Browser “Normal” aka “Standard” Window, yours on the left, mine on the right (smaller 13-inch display):
Brave Browser “Normal” aka “Standard” Window, at the top, and “Private” Window at the bottom - both are my browser:
RESULT: No background color that you experience.
I would test both the Brave Browser “Normal”/“Standard” window, and the Brave Browser Private window - taking screenshots that you will display here, using website: https://search.brave.com
Also test, by creating a new Brave Browser user profile, in order to find out if you get a different result (test, using the https://search.brave.com site) >
Create a new user Profile for Testing:
Create and use AN ADDITIONAL Brave Browser user Profile (Menu --> More tools --> Add profile) - only ← meaning: Do not have any other Brave Browser user Profile tabs/windows open.
When creating this new Brave Browser user Profile for test purposes
  • Do not import anything.
  • Do not add any extensions.
IF this test Brave Browser user Profile does not present your problem, then possibly, the profile that you have been using, has a problem . . . and that might be caused by one or more extensions, or too many tabs ← complex/conundrum.
Detailed info about testing - IF, in regard to memory and performance issues:
Create a new profile to help Troubleshoot
