Description of the issue
Not sure if this is a bug, but I can’t use Wayback Machine to capture a page.
When I try to capture a page, I always get HTTP ERROR 400.
Steps to reproduce:
- Disable any extensions you have.
- Open https://archive.org/web/
- Turn off Brave Shield
- Enter the URL that you want to archive under “Save Page Now”, then click “Save Page”.
- It will show an error.
This problem doesn’t happen on Incognito Window. Just repeat the steps above, but open Wayback Machine on Incognito Window. It will successfully archive the page.
Exact URL of the website in question
Did the issue present with default Shields settings? [Default states are: Block: Ads/Trackers, 3rd Party Cookies, 3rd Party Fingerprinting Allow: Encrypt Connections enabled (HTTPS), Scripts] (yes/no)
Yes.
Does the site function as expected when Shields are turned off? (yes/no)
No.
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no)
No. Whether Brave Shield are turned on or off, the issue still happens.
Does the site function as expected when using Chrome? (yes/no)
Yes.
What Brave version/Build are you using when you encounter the issue?(About Brave info)
Version 0.56.12 Chromium: 70.0.3538.77 (Official Build) (64-bit)
Windows 10 Home 1709 x64
