Hi friends.
Some days ago I bougth a SSD and reinstall Windows and software.
But in my work I need use this web (https://acad.huetamo.tecnm.mx/ITSH/inicio) but I can not enter, I used Brave´s help, other internet´s web and I still in the same.
Thanks.
Description of the issue: I can not enter to web
**Exact URL of the website in question:**https://acad.huetamo.tecnm.mx/ITSH/inicio
Did the issue present with default Shields settings? (yes/no) yes
Does the site function as expected when Shields are turned off? yes
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): no
Brave version (check About Brave): yes
Hi @monjino23,
Can you try accessing the site with Shields on but with all cookies allowed enabled.
I did it, but It does not have change.
@monjino23,
What kind of website is this exactly? Is it accessible to the public? I can’t seem to get it to load using any web browser (Brave or otherwise)?
It is a website to back up the evidence of my students. It a website for use the all teacher in the school.
Evidence about schools´s works.
I can load with chrome.
@monjino23,
Do you need to be connected to a VPN or on a specific network in order to reach the site? Again, I don’t seem to be able to load it at all on any browser, but that may be because I’m located in the US.
Good news.
I have reinstalled brave, and I am Ok.
Thanks.
Best regards.
