Brave Sync Issue: Data Not Syncing on Laptop from Sync Chain
I’m using Brave on my mobile, where I have a long browsing history, saved passwords, and some extensions. Previously, my laptop was part of the same sync chain, but I had to uninstall Brave from it for some reason. The mobile device remained connected to that sync chain. Now, after reinstalling Brave on my laptop and entering the sync code, nothing syncs—no history, bookmarks, extensions, or saved passwords.
Interestingly, everything syncs perfectly when I create a new sync chain and connect a different device—even extensions transfer correctly. So the issue seems to be only with my main Brave account that was part of the original sync chain.
I’m not sure how to reproduce the issue. What can I do to fix this?
