I was typing text into a forum reply window and went to close another tab that I didn’t need anymore. Suddenly all my tabs disappeared and an old set of tabs reappeared. I know it was an old set because it was a set that had disappeared last time this happened and it included some unrefreshed tabs from various forums that I check routinely, as well as some search items that I’d finished with a couple days ago.
- Honestly not sure because I don’t know what caused it. The only thing I can be pretty sure of is that I was changing tabs and suddenly the whole tab bar changed. The first time it closed all my current tabs and took me to a single blank tab, the second time (just now) it took me back to the tabs that had been open the first time.
1.48.132 Chromium: 111.0.5563.147 (Official Build) (64-bit)
New Dell XPS13 Plus laptop, had it about two weeks, no modifications made, all software up to date, only browser installed other than Edge that came with the OS and that I don’t use.
Would appreciate any thoughts anyone might have. It 's weird.
