Brave Shlieds Doesn`t Work Properly
**Description of the issue:I have some pop up ads and its very anoying
**Exact URL of the website in question:https://www.cocomanhua.com/12457/2/149.html
**Did the issue present with default Shields settings? (yes/no)Yes
**Does the site function as expected when Shields are turned off?Yes
**Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no):No
**Does the site work as expected when using Chrome?Yes
**Brave version (check About Brave):1.14.86
I know this isn`t ur fault. The website did change the domain
These type of sites use revolving ad domains (often used on video streaming sites also). I’ve added a few new filters, but will keep an eye on it. Not a permanent fix, and do expect the site to change
But will you “fix” it?
Do you have a temporally solution or something?
Give it 24-48hrs for the update to go through
Ok man srry for pressure you.
Did you alredy fix it?
Because at least in this manhua doesn’t appear more ads.
https://www.cocomanhua.com/13067/1/75.html
Thank you so much. <3
Yes its fixed (just checked). They’re using revolving adserver. Will keep an eye on it.
Me and my bad luck.
I wrote that and the ads appear again xD.
The site just blocked us from accessing it with an adblocker on.
I think it detected that ads are being blocked.
Okay, will investigate.
