The ClickUp extension is unable to be used on any site where shields are up, showing only the login screen (which does not work, I’ve tried.)
This issue is resolved by disabling shields for the site and refreshing, but it would be helpful to not have to do that every time. I assume this just requires some of ClickUp’s CDN urls to get whitelisted?
Steps to Reproduce
- Download the ClickUp chrome/brave extension.
- Click the extension on any site with shields up, you will only see login screen.
- Disable shields for the site, refresh.
- Login now
- UI shows properly.
(with shields Up)
(with shields down)
100%
Version 1.41.100 Chromium: 103.0.5060.134 (Official Build) (64-bit)
Additional Information: N/A
