ClickUp Canny Login Fails Using Brave (Solved)
Can’t log in on ClickUp’s Canny page ( https://clickup.canny.io/ ) using Brave Browser
Note:
  • Other browsers work normally and login without problem
  • Disabling Brave Shield on Canny or ClickUp doesn’t solve the problem
  1. Login to ClickUp ( app.clickup.com )
  2. Go to clickup.canny.io
  3. Click sign in and select your account. It will just redirect you back to clickup.canny.io without being logged in.
I could sign in.
Version 1.2.43 Chromium: 79.0.3945.130 (Official Build) (64-bit)
I would suspect a cookie issue, Allow all cookies in shileds on both domains app.clickup.com and clickup.canny.io. Can you re-test @Zeinf ?
It works. I can now login on https://clickup.canny.io/
By doing this
Allow all cookies in shields on both domains app.clickup.com and clickup.canny.io .
