Brave shield Global settings resets!
@TRILOK,
I’m going to have to reach out to the team here because I do not know what the issue is. If you’ve ensured that you’re not clearing anything On exit, your extensions are disabled, new profile shows the same behavior then there must be something obscure at play.
I know it may be a little cumbersome, but another useful test might be to try downloading our Beta version and test to see if you see the same behavior there. Note that installing/running the Beta will not have any effect on your current browser installation – they will run independent from one another.
Cross checked all and am sure about them. Note that the test profiles doesn’t have any problem, main profile is bugged for now. New sessions of test profiles always starts with aggressive settings as per the previous configuration tweaked by me. But main profile is unstable always :pensive:
Thanks for your help @Mattches , will try the beta too!
@TRILOK,
You’re very welcome. However I’m really not sure what is causing the issue in your main profile. I’ve reached out to some team members but not a lot of responses we haven’t already tried yet. Still digging but I’m glad it’s likely something isolated to your profile, rather than an underlying issue with the software.
