Briefly describe your issue: Brave rewards for two android devices for December disappeared and not creditted. Only one creditted was for my Windows Desktop
What Operating System and Brave version are you using (Menu --> About Brave)? Android, one version 10, one version 11, Brave version 1.33.106 chromium 96.0.4664.110
**Is your browser wallet currently verified? (yes/no)**yes
What date did you verify your wallet? May 2020
Have you been able to successfully receive payments in the past? Mostly
Are you using a VPN? (yes/no) No
**Are you in a supported region (see here for list of supported regions)?**yes
**Does your device pass the SafteyNet check (Android only)?**yes
**Have you manually turned off Auto-contribute on all of your devices linked to Uphold??**yes
