Brave Rewards Receiving Issues
Hello everyone,
I have been using Brave Browser for more than 6 months, and all was good and I was claiming my rewards normally the first 2-3 months. But suddenly, after it I was working normally in the browser as usual but my rewards didn’t add up to my balance.
May I know what’s the problem?
Thanks you
@JanoG27 Can’t answer because you erased the template that Brave generates and asks you to answer when you create a topic. Please provide the info as requested:
Briefly describe your issue:
Are you using a VPN? (yes/no)
Are you eligible for Brave Rewards (see here for list of supported regions)?
Are you on the list of supported regions when verifying Brave Rewards with a custodial partner (see here for list of supported regions)?
Have you manually turned off Auto-contribute on all of your devices linked to a custodial partner?
You may raise a ticket at
What Operating System and Brave version are you using?
Version 1.51.110 Chromium: 113.0.5672.77 (Official Build) (64-bit)
Is your browser wallet currently verified?
No
Yes , sometimes because some websites do not let me access without VPN
Are you on the list of supported regions when verifying Brave Rewards with a custodial partner?
No, I am not a supported region
Yes
I have a same problem. I have received BAT to uphold from one device, but haven’t received from my second device. BAT just disappeared.
Is second device running Nightly by any chance? I only ask because a couple of us have had issues with disappearing BAT on Nightly recently.
@Dado what’s your ticket number?
Ok. I’ll tag in @SaltyBanana and @Evan123. Hopefully they’ll be able to follow-up with you soon.
Taking a look. Thanks!
Are you sure ? Maybe it is in your Uphold account. Instead of 2 it could be bundled into one perhaps ?
