Brave Rewards not Connecting with Uphold
Briefly describe your issue:
I had been able to connect my Uphold Wallet and receive deposits in the past. There was an issue recently with that connect and I also wanted to try Gemini. So, I connected Gemini and received the deposit today. I’d like to use Uphold going forward (automatically converts into USD and emails me when there is a deposit) but when I try and connect to Uphold, it goes to a page to Authorize the Application and then goes back to the dashboard and I receive a message at the top “Could not configure BAT deposits for Uphold”
What Operating System and Brave version are you using (Menu --> About Brave)? MacOS
Is your browser wallet currently verified? (yes/no) yes
What date did you verify your wallet? 2021
Have you been able to successfully receive payments in the past? YEs
Are you using a VPN? (yes/no) YEs
Are you in a supported region (see here for list of supported regions)? YEs
Reward flaming button not show previous month and today (2mOnth
