@Eumaios
Brave Browser requires study. Often, other members of the Brave Community, will view the proceedings of a reported issue, for study or other reasons.
Because some visitors probably do not know what a MyNode is, I replied with reference material . . .
But I also replied, trying to help you be more forthcoming and report your Exact URL of the website in question.
You do not have to reveal your LAN subnet numbers, but you could have reported: http:/mynode.local/
Your Brave Browser settings, might only be allowing HTTPS connections. You may need to locate the settings that are part of Brave Browser > Settings, where you may disable the (something like) ‘upgrade to HTTPS’ settings.
Given, whatever are your site-specific Shields (Lion icon) panel settings (Shields v1 or Shields v2), plus you Global Shields settings that are part of Brave Browser > Settings . . .
You may need to Allow a cookie source and / or a javascript source, in order to satisfy the built-in (embedded, some say) web server of your MyNode device.
You might have one or more extensions that are somehow preventing Brave Browser from succeeding at making a connection.
I do not know if a MyNode device’s built-in web server expects cookie interaction with an Internet browser, but if so, the following might work, though I am uncertain . . .
In a Brave Browser > New Window, go to: brave://settings/cookies
Scroll down that settings page, to Sites that can always use cookies
Click the Add button
Enter [*.]mynode.local as the site . . . but Do Not Enable:
Current Private session only
Including third-party cookies on this site
Next, go to: brave://settings/content/javascript
Scroll down that javascript settings page to Allowed to use javascript
If not successful, then substitute the LAN IP address of your MyNode device, for the character string:
in both of those (the cookies and javascripts) entries or make additional entries.
EXAMPLE: Enter [*.]192.168.5.32 as the site
Because I am uncertain about what you see in your Brave Browser window, when you try to connect to your MyNode device’s built-in web server, I did not previously reply with a method for allowing javascript.
I always use HTTPS, if I can. I expect to find the small padlock icon at the left end of an Internet browser URL address field.
But I am not sure if you see that padlock icon (locked or un-locked)? You might only see an icon that is a dull-red field circle with a very tiny symbol within it.
Using the following screenshots, you will get the idea, of a method for enabling javascript for a web page / website:
Right-click on that little padlock icon (or whatever is the icon that you are seeing) . . .
