Greetings
I’ve noted for some months now, since using Brave Nightly often, that each time I click-drag tabs when they’re in vertical tabs orientation, there is firstly what seems to be a ‘tremor’ effect while dragging the tab, then all of the icons of each tab disappear, the font seems to change, and it of course makes it impossible to appreciate what site the tab writing is from as a result. An effect that I can’t seem to reverse, unless I reboot the browser.
my tabs vertical tabs are to the left side of my monitor.
click dragging tabs used to instantly crash brave nightly months ago. I’m glad that was seemingly fixed.
However, now, click dragging tabs to rearrange them (move one tab above or below another for efficiency or to have it closer to another tab of similar vein or within decent ‘distance’ from one on which i was currently working, etc), creates an effect that is an after effect of the former crashing bug, without actually crashing.
