**Description of the issue: Brave will not load Proton Mail or Brave’s own site both have the same error. Error is:
brave.com is blocked
brave.com refused to connect.
ERR_BLOCKED_BY_RESPONSE
When turning on Developer Tools I see the following:
(index):6590 crbug/1173575, non-JS module files deprecated.
expect(!loadTimeData, “should only include this file once”);
loadTimeData = new LoadTimeData;
window.loadTimeData = loadTimeData;
console.warn(“crbug/1173575, non-JS module files deprecated.”);
Filed a case with Proton Mail - and they mentioned several other Brave users reported the same issue. I have reported this via Hamburger>Help>Report Broken Site
**Exact URL of the website in question: https://brave.com/ and https://mail.proton.me/
**Did the issue present with Defaul Settings? : yes
**Does the site function as expected when Shields are turned off? No
**Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): No
**Does the site work as expected when using Chrome? Yes, Safari also works
**Brave version (check About Brave): V1.60.114 Chromium 119.0.6045.124
