Description of the issue: Brave browser is resorting to Russian (Yandex) How can this issue be reproduced? Every time I open the browser and search, Yandex is taking over
I tried re-installing and clearing cookies and all, no difference
I have no extensions as far as Iâm aware
I have never installed or chosen Yandex it just happened when I was in South America
I want to use Brave, but if I cant get rid of this strange hijacking, I will stop using it
Sorry for the delay in replying: RL issues have kept me from scrolling back this farđ¤ˇââď¸.
Thank you for responding to my plea for helpđ¤.
Nope, it didnât matter if I searched from the search bar or address bar (the problem began with the ânew page Search barâ after the latest Brave updateâŚWhich coincided with a Windows update. Anyway it didnât matter which method I used, I was redirected to Yahoo search results. As Iâve never used Yahoo as a search engine, ever, that I can recall, but especially since I switched to Brave in 2020, it was truly a bizarre choice.
(I began using MS Edgeđ¤Ž, temporarily, and using my phone to access my logins. Whew! I was scared to death that uninstalling Brave and d/l & installing a new copy of Brave, that Iâd lose all my logins & passwords; even on my phone!)
Whatever the problem was, it fixed itself 3 days ago: My Windows 10 laptop did another update at the same time as my Avast A/V. The Avast asked if I wanted it to update my Brave too. I said fine. When I woke up that AM, my pc showed it had restarted, so I cautiously clicked on my Brave shortcut and voila: It acted like itâd never had a problem!
I love Brave, most of the time; the only time I have a problem is with the âimage searchâ being so limited. I usually switch to DDG search at those timesđ¤ˇââď¸
Thank you, again for your time & attention.
Melissa
Btw, I switched to Brave in 2020 when I discovered that Firefox had suddenly been taken over by folks who didnât like my politics and was actually impeding my searches and blocking conservative sites & videos. So happy I switched! Bless yâall!
âExport Passwords - Selecting Download file will export all credentials youâve saved in your browser as a .CSV file onto your system. Note that anyone who has access to your system will be able to open and view this file, so it is recommended that you delete this file once youâve used the file for its intended purpose.â
Be sure to safely store a copy of that CSV file on an external drive.
How to back up your Bookmarks as an HTML file
Two ways to get to the Bookmarks Manager.
One way:
Launch Brave and open the Main menu:
Select Bookmarks --> Bookmarks Manager
Open the More options menu at the top right
Select Export and choose where you want to store the exported file.
Another way:
In a new Brave Browser window, go to: brave://bookmarks
Locate the âOrganizeâ (vertically-arrayed 3-dot) menu button in the upper-right area of the window; click on that
You should get a pop-up menu, in which you click on the âExport bookmarksâ selection and choose where you want to store the exported file.
The exported file name: âbookmarks.htmlâ
Be sure to safely store a copy of that HTML file on an external drive.
After the initial installation and setup of Brave Browser (âBBâ) for Windows OS users, the original BB user profile data is within the Default folder:
You should verify that location; in a BB New Window, go to brave://version and scroll down to Profile Path.
Without BB running, and before doing anything else, also make a backup of the User Data folder . . . placing the backup somewhere that is safe and NOT within any BB installation path.
PS. A variety of problems are solved by:
In a BB New Window, go to the Basic tab at: brave://settings/clearBrowserData
Nope, it seemingly âfixed itselfâ during the last updatesâŚWhether it was the Windows update or the Brave update?
Thanks!
Now though, Iâm afraid to let Brave update again! It ainât broke, quit âfixingâ!
MelJ
I just gave up using Brave on that laptop. Too many hours spent trying to figure out how to fix it. Not worth my time. Maybe a complete fresh windows reinstallation would fix it but I have too much other things to do. Thanks for the help thoughđ
