Brave going windowed when closing while at minimized
same as the title, brave somehow going to windowed insteaad off fullscreen (last session) when closing while at minimized
brave version: 1.80.125
windows version: Windows 11 IoT Enterprise LTSC 24H2 Build 26100.1742
@Davidhench this is the OS and not the browser controlling it. If you do the same thing with File Explorer, any browser, or just about any app on your device you will see it does the same thing.
The OS reopens windows to be similar to what it was when closed. When minimized it is not full screen, so it won’t open full screen. What we see is the OS default size and location.
nah apologize for that, i didn’t know that. i think it shouldn’t like that at least on windows 10.
It’s been so long since I used Windows 10 that I can’t remember the default behavior, but I’ll take you at your word that this is something they changed with the newer OS. But yeah, I get that it might feel annoying.
well, do you have any solutions for it? i know this isn’t brave fault but lemme know if there have an solutions
Not really, especially if you’re launching it from the taskbar. If you were using a desktop shortcut, I would suggest right-clicking it, selecting Properties, and setting the Run option to Maximized.
But if you’re always using the pinned icon on the taskbar, I think the only solution is to avoid closing it from the context menu while it’s minimized. Instead, you can use Alt+Tab to switch to the window and Alt+F4 to close it. That can be just as fast or even faster than hovering the mouse, right-clicking, and selecting Close.
