Brave auto logs me out everytime when I close and reopen it. Tried clearing cache and browsing data, reinstalled brave. But nothing works . Any solution?
Hello @vignesh1619
are you sure you did not choose to clear on exit
brave://settings/clearBrowserData
Yes. I did not enabled that option yet it logs me out every time when i restart BRave.
do you start brave in private mode ? if not could you disable all extension then try again
could you start new profile and test if it work there with the new profile ?
Alredy tried wtih 3 diff profiles. Reseted whole browswr. Reinstalld it. Nothing works
do you clear cache manualy before you exit or after you start brave?
do you have any app that clear browser cache installed (i am not talking about extension here)
Just do not clear cookies (not cache) on exit.
No bro . will not do that.
i wont clear anything on exit either options enabled or manually. i m using brave for one year. i nvr faced problems .
@vignesh1619 if thats the case, maybe update is to blame here than? Try to downgrade (uninstall last update) and see what happens
