Blurriness problem
Disclaimer: I only forwarded this issue from someone, though we do have the same issue.
so someone in the LTTforum posted something about brave, he says that he’s not going to create another account just for a single issue so that’s the reason why I forwarded it here.
anyways; the person is having issues with how brave browser (and chromium-based browsers as a whole) render the images and text, it seemed blurry.
now, this isn’t something that most of us brave veterans here would notice but from a person’s perspective that has just moved on from firefox to brave, the difference is huge and it gets annoying too. As a matter fact, when i actually installed firefox to compare the blurriness i couldn’t unsee the difference (still sticking to brave don’t worry)
  1. have brave and firefox installed
  2. open a website like linustechtips.com (not sponsored) or community.brave.com
  3. compare the home icon and the text of the said webpage in firefox and brave.
brave looks blurrier than firefox to put it simply.
we both have the latest
Version 1.28.106 Chromium: 92.0.4515.159 (Official Build)
@crcl,
I would suggest they try disabling Hardware Acceleration in the browser and see if this fixes the blurry text issue.
Settings --> Additional --> System --> Hardware Acceleration
(Note that they will have to relaunch the browser after toggling HWA off before the changes will take effect)
I forgot to add additional informations, sorry but from the original post:
I’ve dealt with Chrome having blurry text before, but what intrigues me is the the blurry LTT logo as well. I’ve tried the many quick fixes found my searching including:
-Setting windows DPI scaling to 100%
-Run ClearType tuner
-Disable full-screen optimizations for Brave
-Disable all smoothing/anti-aliasing settings in Radeon software
-Disable hardware acceleration in Brave
Nothing has any effect whatsoever. It’s also worth noting that it isn’t an extension issue. The only extension I have now is SponsorBlock, and the blurriness was there from a fresh install.
edit: trying to tag you because i forgot
Thank you for the information that’s very helpful – however it does knock several of my next suggestions :sweat_smile:
Since you mentioned Chrome, I’m curious if Chrome – or any other browser you might have installed – also shows blurry text or if it’s just Brave?
It’s a Chromium issue, quickly tested with Hibbiki’s build from https://chromium.woolyss.com/.
