Description of the issue: I have been using Brave as the default browser for years. I have a new computer and after a month of use, suddenly and probably after some of the updates of Windows 10, or of the Nvidia card, all the texts appear blurred.
I have tried other Chromium-based browsers and all of them work perfectly without any problem. I have tried all the indications of all the tutorials I could find: disabling hardware accelerator in Brave, activating ClearType, setting edge smoothing in screen fonts, default settings, uninstalling and installing again the browser, scaling etc. and I could not correct this problem.
I hope you can help me to fix it, as it is the default browser I prefer to use, but I can’t do it with this problem.
Thank you very much
Greetings
- It only happens in my PC.
- I have not changed anything in the configuration of the browser and I can´t figure out what is happening
Expected result: Help to solve the problem
Brave Version: V1.18.78 *Upgraded Chromium to 87.0.4280.141 (64 bits)
