I’m not entirely sure where the issue lies, or if it even is an issue to begin with, but I noticed today that background processes were not running while the browser is closed, despite the setting being enabled. This is primarily impacting the Snowflake extension, causing it to turn off when the browser is re-opened. Furthermore, the option to let it keep running when the browser is closed has vanished. While I would normally just ignore this and move on, the fact that it’s keeping my Snowflake proxy from working properly is what tipped me off.
The first time I noticed this, I thought it was because my antivirus restarted my computer, and that it would resolve itself after the computer is turned off, then turned back on. The issue persists.
I know background apps are not running since I no longer see the Brave icon in my taskbar tray. Furthermore, the Snowflake icon in the browser is not changing based on the presence of an active connection or connections made in the past 24 hours since the browser was opened, remaining purple and without listing the number of connections on the icon.
Not sure - Happened practically overnight without any settings being knowingly changed
Brave icon appears in tray, Snowflake remains on, while showing number of connections in past 24 hours on the icon in the browser.
Version 1.69.153 Chromium: 128.0.6613.85 (Official Build) (64-bit)
OS: Windows 10, build 22H2
This topic ( Problem with "continue running background apps when brave is closed" ) may or may not be related.
The Task Manager still shows several Brave processes running simultaneously while the browser is opened.
I checked the GitHub page, and no similar issue was noticed.
I have attempted to disable “Continue running background apps when Brave is closed” and re-enable it. Nothing changed. I also just now noticed that “Volunteer to help others connect to the Tor network” was automatically turned off when I opened the “Privacy and security” section. Re-enabling it did not change the situation.
I have a few hypotheses:
1: This is a bug introduced in the latest version, either due to it being tied to Chromium as a whole, or strictly just Brave. (Someone else will need to try this on a different Chromium browser, since Brave is the only Chromium browser I use.)
2: The Snowflake extension was updated and greatly weakened. (Interestingly, the Firefox version of Snowflake doesn’t have the ability to run in the background when Firefox is closed, meaning it now acts as it does on Firefox.)
3: This was an intentional change to the Brave browser.
4: An extension was updated, and is interfering. The extensions I have have not been changed since my last post ( No Audio in Brave Talk )
5: Tor is being suppressed.
If I should test this on a fresh profile to see if some setting has been messed with, I can.
