Setting “Continue running background apps when Brave is closed” is not working.
I restarted the computer with not result. Brave will now close completely every time I close all Windows, and never shows an icon in the taskbar, regardless of whether the toggle is on or not. I have tried turning it off, restarting, and turning it back on and it did not help.
Brave Version : 1.18.75 / 87.0.4280.101 official version (64-bit)
@BugLocker,
Thanks for reaching out to us.
What exactly is it that you would like to have running in the background?
The Brave browser as the setting “Continue running background apps when Brave is closed” says , for faster reopening of Brave.Right now , i uninstalled Brave , and i downloaded and use Brave-BETA. The setting works OK and the Brave run in background when is closed.
I am waiting to fix the bug for official release.
