Android rewards not syncing with Uphold
I finally reached the 25 BAT requirement to sync with Uphold. I logged in and it shows in the browser that it’s synced, however the balance of BAT that’s displayed in Brave doesn’t reflect on Uphold. I figured that maybe I just needed to wait for the BAT to get sent to my wallet, but it never did. I haven’t tried disconnecting and reconnecting my Android wallet because I’m worried I might lose my BAT.
Here’s what it shows in Brave:
Here’s what it shows in Uphold:
I have the same problem
In another post I saw, an Admin was asking to check on your phone with the app https://play.google.com/store/apps/details?id=com.flinkapps.safteynet&hl=en_US&gl=US if your mobile pass the test…
@Jon171,
It appears that you have everything set up correctly. It’s likely that you’re running into an ongoing issue that the team is working hard to resolve:
We apologize for the inconvenience. Note that – assuming this is the issue you’re facing (I do believe it is), you will receive any BAT that was “stuck” this way once a fix is implemented.
