I am an unrepentant, unrestrained tab opening user. (I’ll return to them, eventually… I swear!). I have two monitors. It would be nice to keep my vertical tab list in a separate window on the second monitor to free up real estate on the primary monitor. (Yes, I know you can collapse the list but it takes a second for them to appear when hovering the mouse over it and I don’t really like that).
Related topics
| Split tabs to a new window | 0 | 2835 | January 2, 2020 | |
| Window Based Vertical Tab Collapsing | 0 | 113 | August 23, 2024 | |
| Vertical tabs - allow right (or left) side | 4 | 4315 | January 19, 2024 | |
| Vertical Tabs left or right per window | 2 | 681 | January 19, 2024 | |
| Allow separate windows to have different settings for vertical and horizontal tabs | 0 | 249 | January 22, 2024 | |
| Vertical tab -- click to always show -- should be allowed per-window (mouse-over, per-window, all-windows) | 2 | 254 | January 31, 2025 | |
| Vertical tabs syncing on every window | 0 | 37 | December 30, 2025 | |
| Ability to minimize vertical tabs in a specific window | 6 | 770 | September 16, 2026 |
