I am having an issue where I am still getting AI search result summaries even though I have turned that feature off. I have searched these boards and have implemented every suggestion I could find that might be applicable. The pattern I have noticed is if the search seems to relate to a place, I get the AI results even though I have turned them off. To be clear, I appreciate that Brave absolutely has the right to offer AI search features. I just need to have the option to completely disable them. Thank you in advance for your help!
Related topics
| Toggled The AI Summary Feature Off- Didn't Work? Is this a bug? | 15 | 357 | November 11, 2025 | |
| Brave Search still answering with AI despite the setting being turned off? | 9 | 1671 | December 15, 2025 | |
| Is there a way to turn off Brave AI at my desktop? | 9 | 14568 | June 14, 2024 | |
| Unable to disable "Answer with AI" | 1 | 412 | February 22, 2025 | |
| How to turn off the AI summary | 2 | 1796 | January 21, 2025 | |
| Why AI in Brave search? Don't want it | 2 | 76 | September 2, 2026 | |
| Cannot perm turn off "Answer with AI" searches | 15 | 723 | March 6, 2026 | |
| Removing Search with AI + taking you up on the offer to explain why | 6 | 561 | November 29, 2024 |
