I have my MacOS highlight color set to grey, however, since about 3 updates ago, whenever I select the address bar in Brave, the highlighted color is blue, instead of the system wide color grey.
- Set system highlight color to grey (or any other color)
- Select address bar in Brave
- Highlighted color is blue
Highlighted color should be system default, ie: grey
V1.32.115
This started happening 3 updates or so ago. Still not fixed. Using Monterey.
