Add native customizable mouse gestures to improve productivity and power-user workflow
I would like to request native, fully customizable mouse gesture support in Brave (similar in flexibility to Vivaldi or Floorp).
Why this should be seriously considered
1. Productivity impact
For power users, workflow speed depends on minimizing friction. Mouse gestures reduce context switching between mouse, keyboard shortcuts, and UI controls, making navigation and tab management noticeably faster.
The lack of native mouse gestures is currently the only feature preventing me from switching to Brave, as it directly limits productivity.
2. Native implementation vs extensions
Existing gesture extensions can be:
  • Glitchy or inconsistent
  • Broken by updates
  • Conflicting with internal pages
  • Requiring broad permissions
A built-in implementation would provide better performance, stability, lower input latency, and better alignment with Brave’s privacy-focused approach.
3. Ecosystem value
Providing an opt-in, well-integrated gesture system would attract workflow-focused users and strengthen Brave’s position as a productivity-friendly browser. And the people who uses the mouse gestures for some time really get used to it and can’t go back from it.
Suggested approach
  • Fully customizable gesture mapping
  • Gesture editor/recorder
  • Per-site enable/disable
  • Import/export configuration
  • Disabled by default (opt-in)
