Zcash "max" send fails, probably due to insufficient fee reservation
I select "Send->Zcash->“max”:
If I select “Review send” I am returned to the blank screen automatically:
However if I reduce the send balance by 0.0001 ZEC which is sufficient to cover the sending fee, the transaction goes through.
Probably the “max” button constructs a transaction that withhold 0 to cover the transaction fee.
Is the issue occurring on a specific network?
Yes Zcash.
What operating system are you using?
Arch Linux.
Version 1.75.175 Chromium: 133.0.6943.54 (Official Build) (64-bit)
Thank you for reporting! Will raise the issue internally with the team.
