Own HDR display
Windows HDR is on
Open Brave
Go to youtube.com and open a video
Video plays at max saturation
Expected result: Video should play at normal saturation, or there should be controls to adjust it somewhere obvious.
Brave Version( check About Brave): 1.81.135
Image sample:
The workaround I had been using was setting the flag “Choose ANGLE graphics backend“ to OpenGL, but for a couple months now, this causes the browser to not open correctly, it just opens an empty window with a gray background.
Hello,
I have this exact same issue, it’s not as saturated as you, but i can’t find a way to get around
Forcing ANGLE to OpenGL just open a blank brave browser window with nothing in it
Versions :
I’m not having this issue on other browsers like Chrome or Edge or Firefox.
Also, when totally quitting the brave process (not just closing the concerned window, aka closing all window and making sure the process is down), then restarting Brave, the video tonemapping is correct for few moments, until it sudenly go Saturated again.
When moving my video window to a non HDR screen, colors are OK
Issue is not with YouTube, i have the same issue with twitter or any video on any websites
It’s a big problem for me, what can be the solution ?
I’m not having this issue with a Radeon RX 7900 XT (but do faintly remember having weird issues with my 1080 Ti).
By chance, what happens if you go to brave://flags and look for “Force color profile” and set it to “scRGB linear”, then relaunch? That causes Brave (and any Chromium based browser for that matter) to stop using 8-bit sRGB with the Windows DWM, but rather use a wide gamut 16-bit float with wide gamut support (my theory is this may band-aid the issue).
(Side effect to doing this, is if you are in SDR mode on Windows 11 with “Automatic Color Management” enabled, you will now be in 30-bit deep color mode, and scRGB’s color profile does let Chromium browsers to access billions of colors now. So don’t be surprised if YouTube’s HDR videos playback in SDR mode now. Also, Brave will be a bit darker in HDR mode with scRGB, however videos won’t and shouldn’t be.)
Oh, and there is an HDR10 profile specific as well, so perhaps that one is better suited while in HDR mode, and scRGB is better for SDR mode with 30-bit/wide gamut support.
Hello,
Thank for the tip, i will try to force color profile when the issue will arrive again. (as this happens randomly, and today it’s not broken yet)
Loosing HDR video is quite an issue but not as having all my videos over-saturated
Yea, and it’s always worse when it’s intermittent. I did just check, when in HDR if it has issues, use only the HDR10 profile, not scRGB. I did confirm, HDR10 is for when you’re in HDR, whereas scRGB is merely for us who are in 30-bit “Deep Color” (billions of colors) in SDR mode (does unlock HDR videos in SDR mode, but that’s something above me, haha).
Hi,
I did try to force some color profiles with that flag, but none solved the issue.
Currently I am using the flag “Choose ANGLE graphics backend“ as D3D11on12, it seems to be working somewhat, but it causes other issues with the browser.
Like for example sometimes tabs are not showing any content until I duplicate the tab. And when mouse overing videos in youtube sometimes every browser window goes empty for a second or so… But I can manage with this…
This almost sounds like a GPU issue then (not like a physical hardware issue, but maybe a driver hiccup). What GPU are you using? I’m on a 7900 XT, and simply aren’t having these issues, but while my Angle backend is the default, I am however using Skia Graphite (fixes colored block issues on AMD GPU’s).
