YouTube doesn’t play video if you select a resolution higher than 480p since the last Brave Mobile updates from about a month or so.
- Open YouTube
- Select resolution to 720p or 1080p
- No video, just audio
Play both video and audio as usual. 480p and below resolutions perfectly work, this is whether wireless is on or not, connection doesn’t matter. Edge can perfectly play 1080p on same device.
Brave 1.64.109, Chromium 123.0.6312.58
and also
Brave 1.64.113, Chromium 123.0.6312.86
Mobile Device details
Samsung Galaxy S8, Android 9
We have 2 identical Samsung S8s
Mine has the latest Brave with this issue.
My wife’s instead is on a previous release (update failed for a chance) and her phone can perfectly play 720p and 1080p, please roll back whichever change affected this. Many users are having the same issue now.
My wife is on 1.63.165, Chromium 122.0.6261.94
thank you,
Gabrio
